Firmware Hikvision DS-7608NI-E2 / 8P NVR firmware update?
Thanks for the quick response. What's the out if things go wrong? I have located a copy of the firmware V3.4.95 build 170626.
If the firmware works I wouldn't expect there to be any major problems as this update is only a couple of versions newer than your current firmware.
If your NVR is from the AUS region and this firmware is just completely incompatible, the update will just fail and not complete.
If the upgrade is successful, you probably won't be able to downgrade to your old V3 firmware as the upgrade will have stepped you into the V4 firmware versions which bring lots of new updates including the new V4.0 GUI.
The good news is the update to V4.1.10 build171107 worked. One slight issue so far is one camera not displaying in split screen. I have 5 camera's so I have a 3 * 3 split. It does display just 1 view. Do we go further or leave it at that?
Thanks for your help. A bit of a haul but I've managed to install all the firmware updates, and all appears well.
How do you keep on top of the latest firmware when it arrives?
The next step is to attempt the camera firmware update. They are currently running V5.5.0 build 170725.
Using one of the serial numbers (all the same model) and HIToolsDelivery it is recommending V5.6.2_190701. I've found this firmware on the EU portal.
Not quite sure how to go about this. Upgrade shows a camera upgrade option. Says 'The version is already the latest'. Stumped at this point?
Thanks again
Hi @ogradyr
Good to hear the NVR updates worked, you can always check for the newest firmware versions by using the Hikvision Firmware Tool on their website.
In regards to the cameras, you are quite far behind with the firmware so we would also recommend updating these in steps like you did with the NVR, the list of firmware versions we recommend updating to is below:
V5.5.83_Build190221
V5.6.0_Build190507
V5.6.6 Build210625
I recently introduced a new HiLook PTZ into my set up and all installed perfectly fine.
I used both 'HiToolsDelivery' and SADP to assign IP and as a comparison.
Interestingly the 'HiToolsDelivery' found an online update for my NVR Hikvision DS-7608NI-E2 / 8P
V3.4.103 build181226 installed fine and all is well.
I see there is actually a newer firmware v3.4.106 build 230316 available. HiTools does not find this one online.
I presume this FW will work on my NVR ? It would be good to understand the release notes and what changes they have updated. Hikvision are not great at this !
I would have to do it manually and there is always a risk updating FW so I am uber careful before proceeding with these things.
Also I note the latest firmware v3.4.106 is Multi-Lingual. Does that include English ? Currently all my FW has been the EN versions up until now and I am guessing that is why HiTools may not be indicating an available upgrade. There is only the ML v3.4.106 in the repository ?
Hi @ekkostar
You should be fine to update to the v3.4.106 firmware, based on the 2023 release date of this firmware and the fact there was also a 2019 v3.4.106 version makes me think this latest version was probably just a patch for a security vulnerability that was reported last year and won't introduce many other major updates.
The firmware you have linked above is an 'EN' English version.
Ok great.
I was getting mixed up with what was available on the EU portal
Firmwares
So is the EN 3.4.106 version I linked to in the other post safe for me to upgrade to ?
Any chance it may brick my NVR or not worth the risk?
Ok it worked ! All good.
Next question. What is the best equivalent replacement for this NVR in the current line up with the latest features?
Hi Dan,
I have the same NVR and camera's as user ogradyr, I've tried the firmware versions you recommended but both are incompatible. I also thought my software was EU but now I'm not sure.
Current versions,
NVR: V3.4.95 build 170626
Camera's: V5.5.0 Build 170725
I actually like V3 on the NVR, could i just do the camera's first? And any idea what firmware to try?
Thanks for any help.
Hi @InAus355
Did you purchase your NVR in Australia?
Like I explained to ogradyr earlier in this thread, we cannot guarantee that UK/EU firmware will work on AUS hardware.
Here is the full list of NVR firmware versions and Camera firmware versions, you can try updating to some of the other versions between your current firmware and the versions I recommend previously to see if they work.
If not, you will have to try and get in contact with Hikvision Australia and/or an Australian Hikvision reseller/installer help you locate the correct firmware for your region.
Hi @InAus355
Thanks Dan.
Yes, it was purchased on ebay Australia, but I believe it was all imported stock. Purchased in 2018.
So earlier i upgraded all my camera's to V5.6.821 build 230831. All working. That software doesn't come up on that list, it's actually from Canada.
I've tried both the Canada site and the list you gave me, i keep getting upgrade failed for the NVR firmware. Any other idea's?
