- 4,204
- 113
A couple of things
1 - is it possible the main stream of the new cam is set as H265 as that is not supported on your NVR. Often on the newer cameras the main stream defaults to H265 whereas the sub stream defaults to H264. Log into the camera and ensure it’s set to H264
2 - I’ve had a similar issue with a new cam that wouldn’t come online with an older model NVR. I had to log into the camera directly and change the authentication to “basic” rather than “digest” and that cured it. The security on the camera was newer than what was available on the old model NVR.
