Hik-Connect Accessing Hikvision DS-2DE5425IW-AE S5 cameras from Hik-Connect when off-site?
Ok, then that is why you cannot access from the work PC.
The basic IP address can only be used to access the device from a browser on your local network and the P2P connection is primarily used for mobile access.
To access the camera using a browser on a PC outside your local network you would usually need to port forward the camera, but as you have already set up Hik-connect the easiest way for you to do it would be to install iVMS-4200 on the work PC you want to access from and then add the camera to iVMS-4200 via Hik-Connect/P2P Cloud, the steps for doing this are explained in the below thread:
Ok, got it, realy appreciate your help Dan, ;)
Pretty sure i'll come back later with other problems :D
